Jonathan Gilbert
- Mar 19, 2018
- 1
- Joined
- Mar 19, 2018
- Messages
- 1
I have a fairly nice fan in my possession, a BitFenix Spectre Pro 230mm. It is a standard PC case fan, using the 3-pin connector that allows the system to sense the fan speed. My understanding of the pinout is that the first two pins are ground and +12VDC, and the third pin is connected to a Hall effect sensor to feed back information about the fan's rate. I have an application where I want to power this fan without a full PC power supply & motherboard (which is where the 3-pin connectors are typically found, of course). I have a wall wart that puts out 12VDC and is rated for well over the expected current draw of this fan. I have verified with a voltmeter that it is functioning just fine and putting out the expected 12VDC. But, when I hook up the wall wart to the pins on the fan's wire, it does not turn at all. In fact, doubting myself, I tried every possible polarity of every possible pair of pins, and got no results with any of them. After doing this, I plugged it into an actual motherboard and the fan immediately span up.
What am I doing wrong? Is it possible the fan's circuit is designed in such a way that something has to be connected to the Hall effect sensor or it won't operate? Is the motherboard giving the span a special extra spike of voltage just to kick things off that the wall wart wouldn't be doing? What do I need to do to power a 3-pin case fan from a non-standard (but properly-rated) power source?
