J.B. Wood
Hello, all, and after studying the following pic at
http://realneo.us/system/files/Radke-painting-on-concrete-.jpg, the
wiring doesn't seem right. There appear to be two autotransformer
boosters at either end of the mounting platform with a conventional
transformer in between. The transformer primaries are apparently wired
in delta but the secondary connections don't seem to make sense. (A
configuration of three booster transformers (one for each phase) would
seem more appropriate.) I can't seem to construct a phasor diagram of
the wiring shown in the photo and none of my EE handbooks shows anything
like this.
With these components I could connect the taps of the two boosters as
open delta then close the delta with the secondary of the conventional
transformer (assuming it has the appropriate turns ratio). But that
isn't the wiring shown in the photo. There also appears to be 4 wires
going from the transformers vice 3 wires going to the feeders at the top
of the utility poles. Your time and comment is appreciated.
John Wood (Code 5520) e-mail: [email protected]
Naval Research Laboratory
4555 Overlook Avenue, SW
Washington, DC 20375-5337
like this.
