24 Volt DC to 5 Volt DC - need help constructing a simple circuit
It's been a few years since I had an electronics course, so I need help
with a relatively easy question.
I need to reduce 24 volts DC to 5 volts DC. I think it's just a matter
of a couple resistors but am unsure. The amperage is relatively low
(not sure exactly).
Can anyone help? Details would be much appreciated.
-Dan
I
Ignoramus17480
(not sure exactly).
Look up a voltage divider circuit. It is made with a couple of
resistors
+24V ---------------------------
|-------------- +5V
0 -------------------------------------------- 0
i
John B
help with a relatively easy question.
matter of a couple resistors but am unsure. The amperage is
relatively low (not sure exactly).
-Dan
7805L regulator. Costs about 50 cents and comes in TO92 package.
John B
But it might get hot fed with 24V
Yes it might, that depends on the current consumption. But it won't get
any hotter than the dropper resistor in a potential divider and the
output will more stable.
If in doubt use a standard 7805 1A regulator bolted to Mr mcSmoke's
dope tin.
F
Fred Bloggs
(not sure exactly).
Yeah - details are what's needed- the "amperage" is all important so why
don't you find out what it is before your ask your dumb question.
D
Don Foreman
dope tin.
If you're talking about more than 100 mA, consider a Simple Switcher
from National Semiconductor. Check out LM2678-5.0. It won't need
a heatsink for currents up to 2 amps or more. The website "web
bench" will design the circuit for you, including giving you a parts
list.
http://www.national.com/appinfo/power/webench/
Ooohh such anger, now I know who the '40 Year Old Virgin' was based on.
E
ehsjr
Fred Bloggs contributes wonderful circuits here. You would be
very hard pressed to get better help than he can provide - if
that is possible. You mistake accuracy as anger.
Ed
P
Peter Bennett
Fred's response may be a bit blunt, but we do need to know the load
you want to run from the 5 volts. If the current is very low and
stable, a resistive divider may do, but if the load varies a lot, a
regulator would be necessary.
