D
David Farber
My son's car is an Acura 2000 3.2TL. Recently, the SRS light came on.
Searching the web I noticed this was a common problem. Acura extended the
warranty on some of the components in the SRS to take care of this problem.
Initially, the local Acura dealer said the component, an SPORD SRS Unit,
which costs about $300 then another $200 to install, needed replacing. Of
course, that was not one of the components covered by the extended warranty.
When my son asked the service department for the OBD scanner code to do his
own research, he was told it was 13-5. Further internet searching turned up
nothing on this code. The next day the dealer calls and says, never mind,
the battery is weak and that's why the light came on.
The service department then measured the cold cranking amps of the battery
and said it was 220 and that was too low. So my question is if the battery
has enough power to start the car, how can it be so weak as to enable a
fault condition in the SRS? How much power could the SRS need to operate? Of
course my son will get stuck with a $100 diagnostic fee if he declines the
repair. If he gets the battery replaced at the dealer the diagnostic fee
would be applied toward the battery replacement and the final cost would be
$132. I'm thinking that it was just a an onboard computer glitch that
triggered the light and this cold cranking amp measurement discussion is a
ruse to have him buy a battery because they really don't know what's going
on. Appeals to management have gone nowhere.
Thanks for your replies.
