Richard9025
- May 24, 2016
- 205
- Joined
- May 24, 2016
- Messages
- 205
Hi!
When I received this table-top 70s radio from Western Germany, I powered it up (all original parts) and on mediumwave and longwave it was working, on FM and shortwave it was completely dead, no static or anything, also the amplifier was very weak and the left output was 10 times louder than the right output.
Then, I replaced every electrolytic capacitor and the radio now works perfectly on FM, it receives a lot of stations without an antenna, the audio is clear and very loud and balanced. But it has some problems, firstly some photos of the unit:
So here are the problems:
1. Stereo Decoding
The stereo decoding is realised by an optional stereo decoder module that this radio is equipped with. It isn't only not decoding the stereo signal, but it is also downgrading the audio quality. If I press the 'MONO' button, or I just pull out the module, the sound is richer, clearer and louder and ... mono .
2. Stereo FM memories
On the right part of the front of the radio, there are some small scales alongside with some pushbuttons that have black sleeves that can be rotated to adjust the mini scales. The mini scales represents the FM band, the numbers next to them represent the channel (2 to 56 = 87,5 to 104MHz) If I rotate the sleeves, it should change the frequency, but it doesn't. (This function is linked to the stereo decoding module, as this memory function can also provide stereo sound.)
3. No shortwave (not really important)
When I press the "KW" (shortwave), nothing happens, no static, maybe contacts in the ganged switches?
The schematics:
-The version edited by me, to highlight which electrolytic capacitors I changed, and which transistors I measured and determined good (solid green rectangle- good transistor/light green rectangle- replaced electrolytic capacitor or good fuse or bulb / yellow rectangle- unchecked electrolytic capacitor) I also put the mV values of the E-B and C-B junctions next to the transistors.
https://photos.app.goo.gl/TGzk3BWwp5egeNqF2 (size too large to upload here)
-The original version, maybe you want to make some illustrations.
https://photos.app.goo.gl/nhnOXqY61o18efC83 (size too large to upload here)
Radiomuseum link: https://www.radiomuseum.org/r/imperial_hifi_2700_1.html
Many thanks!!
1. Stereo Decoding
The schematics:
Many thanks!!
