A
Alex
I hope you specialists can help me.
Here in the UK I have a magnifying table lamp at home with built-in
illumination.
It uses a 12 Watt circular fluorescent bulb (outer diameter 12cm, inner
diameter 10cm). The bulb has some sleeving with the pins on the very
outermost part - if you see what I mean.
I am having a bit if trouble locating this as most circular fluorescents
I come across seem to be rated at a higher higher power.
Is there a standard ref number for this bulb which I can use to search?
Or does anyone know where, in the UK, I can get this?
illumination.
