12V to 33V Converter
Discussion in 'General Electronics Discussion' started by KUMARA SHP, Jan 7, 2017.
  1. KUMARA SHP
    KUMARA SHP
    Aug 1, 2014
    122
    4
    kandy
    Hi
    I am looking for 33V boost converter.
    Min output current = 300 mA
    I found this design, but not sure about it.
    Please help me.
    I also like to use different circuit. Please suggest me a chip or circuit.
    #1
    1. Advertisements
  2. KUMARA SHP
    Arouse1973 Adam
    Dec 18, 2013
    5,155
    1,070
    Cornwall U.K
    What are you not sure about?
    Arouse1973, Jan 7, 2017
    #2
    1. Advertisements
  3. KUMARA SHP
    KUMARA SHP
    Aug 1, 2014
    122
    4
    kandy
    About functionality.
    Before I make PCB i want to make sure the design.
    Will it produce 33V and about 300mA current .
    I tried to find alternative chip but it was not easy.
    #3
  4. KUMARA SHP
    24,089
    2,336
    Have you looked up the datasheet for the TL594?
    (*steve*), Jan 7, 2017
    #4
  5. KUMARA SHP
    Alec_t
    Jul 7, 2015
    2,336
    604
    Wales
    The 2N3906 is good for 200mA max, so you'd need a higher rated transistor.
    Alec_t, Jan 7, 2017
    #5
  6. KUMARA SHP
    24,089
    2,336
    I'm not sure what purpose that transistor serves.
    #6
  7. KUMARA SHP
    Bluejets
    Oct 5, 2014
    2,464
    480
    On off...?
    Bluejets, Jan 7, 2017
    #7
  8. KUMARA SHP
    KUMARA SHP
    Aug 1, 2014
    122
    4
    kandy
    Yes. Transistor for on off. Yes I looked the datasheet.
    But I don't have so much knowledge to confirm the design
    KUMARA SHP, Jan 8, 2017
    #8
  9. KUMARA SHP
    KUMARA SHP
    Aug 1, 2014
    122
    4
    kandy
    KUMARA SHP, Jan 10, 2017
    #9
  10. KUMARA SHP
    KUMARA SHP
    Aug 1, 2014
    122
    4
    kandy
    Hi
    I am going to design 12v to 33V converter.
    I chose LM2585
    will it work?
    I am going to modify this circuits.
    Please help me, I am not sure about the selection.
    200mA current is enough at 33V output.
    [mod note: moved this post to this thread ... is on the same topic]
    KUMARA SHP, Jan 12, 2017
    #10
    1. Advertisements
