12V Light project
Discussion in 'LEDs and Optoelectronics' started by Joergenvs, Dec 6, 2017.
  1. Joergenvs
    Joergenvs
    Dec 6, 2017
    3
    Hi all,
    I am posting here as my expertise in the electronic field is very limited.
    I want to create a light up system using this product:
    https://www.amazon.co.uk/gp/product/B06XRBY3K6/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
    It has a 12v/24v DC Input, this is used for a car battary, however i want to run it off a 5V USB cable ideally.
    My idea was to use a 5v to 12v USB Step us system, with a DC Connecter plug at the other end:
    https://www.amazon.co.uk/Upgrade-Co...sr=1-6-catcorr&keywords=USB+Step+up+Converter
    Would the system work with the following, would the system work as follows connecting the original light up switch board to the following:
    https://www.amazon.co.uk/DealMux-La...qid=1512548180&sr=8-8&keywords=DC+jack+wiring
    so i can plug the DC power in etc...?
    Kind Regards,
    #1
    1. Advertisements
  2. Joergenvs
    kellys_eye
    Jun 25, 2010
    3,119
    829
    West Coast, Scotland
    If the board you want to power consumes less than the USB converter can deliver then yes you can use the USB power lead.
    The details for the lead are not exactly explicit though - it states 'maximum 2A' but not whether that is the input or the output, nor does the panel you want to power show any details of the consumption it requires.
    But if the criteria are met then there's no reason why you can't power that board in that way.
    kellys_eye, Dec 6, 2017
    #2
    1. Advertisements
  3. Joergenvs
    Bluejets
    Oct 5, 2014
    2,441
    477
    Just seems pointless to power it from 5v to 12v and then back again to 5v to drive a couple of usb charge ports.
    Granted the switch Leds are set up for 12v. So do you intend to drive relays for the outputs(lights)?
    Be a bit wary of the wiring detail as it seems to be a-up.
    Bluejets, Dec 6, 2017
    #3
  4. Joergenvs
    Joergenvs
    Dec 6, 2017
    3
    No, its purely for show to be honest.
    #4
  5. Joergenvs
    Bluejets
    Oct 5, 2014
    2,441
    477
    In that case, just connect a 12v plugpack.
    #5
  6. Joergenvs
    Joergenvs
    Dec 6, 2017
    3
    #6
    1. Advertisements
