Having a problem with a delay_ two led's switch states after a short delay period when a button is pressed to start the sequence. When the sequence ends the program returns to begin ready fr next press. A switch selects the timing period either long 15 min or short 5 min. My problem is the first delay period times OK the second period just hangs.
I only use PIC assembly as can be seen in my example.
Any help appreciated please. Regards Dupe
Code:
;processor 12F675 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
org 0
; This shorthand assigns COUNT1=0x20, COUNT2=0x21, etc.
cblock 0x20
DCounter1
DCounter2
DCounter3
DCounter4
endc
; _INTRC_OSC_NOCLKOUT: we want to use the internal oscillator to drive the PIC,
; so that we don't need to connect a crystal, see "Section 2. Oscillator".
#include <p12f675.inc>
__config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF
errorlevel -302
bcf STATUS, RP0
clrf GPIO ; Set byte at address GPIO in Bank 0 to 0, so that digital pin outputs will be
; a known value (0, low)
movlw 07H ;movlw b'111' ; This turns the comparator off, pins GP{0,1,2} act as digital I/O pins.
movwf CMCON
bsf STATUS, RP0 ; Select Bank 1.
movlw 3454h ;============= read last program memory location at 3ffh and enter hear
movwf OSCCAL
clrf ANSEL
movlw 3ch ;first two bits are outputs . third & fourth bits are input
movwf TRISIO
bcf STATUS, RP0 ; Back to Bank 0 so that we have access to GPIO.
goto begin
; ================================== 100 millisecond delay for debounce ======
delaysw
MOVLW 0Xdc
MOVWF DCounter1
MOVLW 0X82
MOVWF DCounter2
LOOPc
DECFSZ DCounter1, 1
GOTO LOOPc
DECFSZ DCounter2, 1
GOTO LOOPc
RETURN
; ================================= delay 5 mins ============
delay5
MOVLW 0X67
MOVWF DCounter1
MOVLW 0Xe7
MOVWF DCounter2
MOVLW 0Xf2
MOVWF DCounter3
MOVLW 0X06
MOVWF DCounter4
LOOP
DECFSZ DCounter1, 1
GOTO LOOP
DECFSZ DCounter2, 1
GOTO LOOP
DECFSZ DCounter3, 1
GOTO LOOP
DECFSZ DCounter4, 1
GOTO LOOP
NOP
NOP
RETURN
; ==================================== delay 15 mins =========
delay15
MOVLW 0X3f
MOVWF DCounter1
MOVLW 0Xb4
MOVWF DCounter2
MOVLW 0Xd6
MOVWF DCounter3
MOVLW 0X12
MOVWF DCounter4
LOOPb
DECFSZ DCounter1, 1
GOTO LOOPb
DECFSZ DCounter2, 1
GOTO LOOPb
DECFSZ DCounter3, 1
GOTO LOOPb
DECFSZ DCounter4, 1
GOTO LOOPb
RETURN
; ======================== selecting run period ===============
begin
btfsc GPIO,5
goto begin
call delaysw ;call delay.5 ; wait before start
btfsc GPIO,3
goto sh
goto lng
sh ; 5 minute swtching period
bsf GPIO,0 ; green led on
bcf GPIO,1
call delay5
nop
bcf GPIO,0
bsf GPIO,1
call delay5
nop
goto begin
lng
bcf GPIO,0
bsf GPIO,1
call delay15
nop
nop
bsf GPIO,0
bcf GPIO,1
call delay15
nop
goto begin
END
