100K capacitor = 100pf?
Discussion in 'General Electronics Discussion' started by TallPaul, Apr 16, 2018.
  1. TallPaul
    TallPaul
    Oct 5, 2014
    9
    4
    I'm replacing ceramic disc caps in an 80's amplifier and I pulled 5 that had CGE 100K markings. They all measured 100pF. According to the Internet 100K is suppose to be 10pF. They are 10mm wide and thats kind of big for a 10pF. It only has to deal with 15v from the regulator. All the other ceramics of different values measured correctly according to the markings. Could these capacitors drifted that far in 30 years? The capacitors are CGE ceramic discs with epoxy coating.
    #1
    1. Advertisements
  2. TallPaul
    8,371
    1,585
    Germany-Europe-Earth-Sol System-Milky Way-Laniakea
    Agreed.
    No way.
    Shouldn't be necessary unless these are clearly defect.
    Harald Kapp, Apr 16, 2018
    #2
    1. Advertisements
  3. TallPaul
    davenn Moderator
    12,724
    1,586
    Sydney, Australia
    It's a trap that young players can fall into
    it depends on if the 3 digit code is being used eg
    100 = 10pF
    101 = 100pF
    102 = 1000pF etc
    or if the cap is being marked in pF which is also very common, in which case 100 = 100pF
    davenn, Apr 16, 2018
    #3
    hevans1944 and Arouse1973 like this.
  4. TallPaul
    8,371
    1,585
    ... which is the likely explanation here.
    #4
  5. TallPaul
    kellys_eye
    Jun 25, 2010
    3,429
    909
    West Coast, Scotland
    I'd like to see a picture of the capacitors in question.
    My own opinion is that they should be 0.1μF
    15V?? Regulator??? We're talking something like a pre-amp supply in a solid state circuit so 100pF?????????
    Could be a problem with the way they're being measured????
    kellys_eye, Apr 16, 2018
    #5
    hevans1944 likes this.
  6. TallPaul
    Audioguru
    Sep 24, 2016
    2,128
    493
    100k picofarads is 0.1uF. The datasheet for a Texas Instruments uA7815 shows a 0.1uF capacitor at the output.
    100pF will not work. 10pF is stray wiring capacitance.
    Audioguru, Apr 16, 2018
    #6
  7. TallPaul
    8,371
    1,585
    Assuming the measurement is correct, then the letter K is for +- 10 % tolerance.
    #7
    davenn and Arouse1973 like this.
  8. TallPaul
    Robert_fay
    Jun 15, 2017
    99
    24
    100k could be correct for 100pF. Some caps only change to the 3 digit when they go over the 100pF rating. So a 10pF would be marked as only 10 and the K would be tolerance 10%.
    Robert_fay, Apr 16, 2018
    #8
  9. TallPaul
    kellys_eye
    Jun 25, 2010
    3,429
    909
    ....a 10mm wide capacitor on a 15V regulated supply line and 100pF??? Something is wrong with this... all the 100pF capacitors I have (rated at 50 to 100V) are 5mm in diameter and around 1mm thick.
    #9
  10. TallPaul
    Robert_fay
    Jun 15, 2017
    99
    24
    Any chance for a picture of the markings and cap. May clear up some options!
    #10
  11. TallPaul
    Cannonball
    May 6, 2017
    110
    32
    SC
    100k, the 100 is the value of the capacitor in pfs.
    Cannonball, Apr 16, 2018
    #11
  12. TallPaul
    7,172
    1,493
    Worcester, MA
    All my 10pF caps are marked 10 not 100. All under 100 are marked with pF in 2 digits. All my 100pF ones are marked 101. So 100 and 101 might very well both mean 100pF.
    bob
    BobK, Apr 17, 2018
    #12
    davenn likes this.
  13. TallPaul
    TallPaul
    Oct 5, 2014
    9
    4
    And the winner is 100pF. I'm using a Fluke multimeter. They don't look like cheap junk ceramics. Back in the 80's this amp was $600. I had to replace the twin power caps and I don't do anything half a--. I replaced all the electrolytics with Nichicon Muse and all the ceramics with silver micas
    TallPaul, Apr 17, 2018
    #13
    Cannonball and davenn like this.
  14. TallPaul
    kellys_eye
    Jun 25, 2010
    3,429
    909
    Which Fluke? Does it read accurately with other known-capacitances?
    I'd like to see the schematic for the circuit in question to see how they can justify using 100pF on a 15V regulated line.....
    kellys_eye, Apr 17, 2018
    #14
  15. TallPaul
    TallPaul
    Oct 5, 2014
    9
    4
    Finally found the schematic and the Fluke was correct. 100K for CGE brand is 100p. I doubt if this cap company is in business anymore. Since it was early 80's it was pre-China junk era. More than likely they were made in the US
    TallPaul, Apr 25, 2018
    #15
    Harald Kapp likes this.
  16. TallPaul
    kellys_eye
    Jun 25, 2010
    3,429
    909
    I call 'misdirection'...!!!
    your schematic shows the capacitor to be RF suppression/decoupling across the inputs of the op-amp - perfectly suited to 100pF.
    But, back to the original 'fault' - these capacitors rarely, if ever, go faulty. Even if they changed value by 500% it would likely make no appreciable difference to operation.
    kellys_eye, Apr 25, 2018
    #16
    1. Advertisements
