ZIF Edgecard Connector -- 12 Position
Discussion in 'Electronic Design' started by [email protected], Jun 6, 2007.
  1. Guest
    Looking for a 12-position zero-insertion-force edgecard connector.
    AMP has one designed for PCI cards, but it has like 48 positions or
    something. I'd like something smaller.
    The application is a field-test fixture. Requirements for the device
    include: low insertion force, high reliability, modest size, and life
    in the thousands of cycles.
    The circuit board pads are raw copper. What kind of problem does that
    pose? The customer would prefer to not use pogo pins. Don't ask me
    why.
    TIA
    Robert
  2. Rich Grise
    Rich Grise Guest
    I found a 22-position by searching Digi-Key, and followed the link to
    the mfr:
    http://search.tycoelectronics.com/e...ronics&search_type=Part&question_box=531024-2
    [watch for wrap]
    Corrosion. I wouldn't expose bare copper to air in this kind of app at
    all, if I wanted it reliable at all.
    Probably because they cost an arm and a leg.
    But, please, at least get him to _tin_ plate the edge contacts, but
    really, gold over nickel is the most reliable, especially if you expect
    your ZIF socket (with gold plated contacts) to last for thousands of
    cycles.
    Good Luck!
    Rich
  3. Guest
    Rich,
    Thanks for the advice. I think I'll just get that 22-position job and
    give it a try.
    Regards,
    Robert
