A
Adam S
I've have some cascaded op-amp stages, each providing +20dB, and worst
case DC offset is +-30mV at the output of each stage.
I want to AC couple each amplifier stage with polarized capacitors. I
cannot find any documentation recommending the use of polarized
capacitors for continuous reversed bias, even when the bias is very
small (< 50mV).
However there is the following PDF from kyocera,
http://www.kyocera.co.jp/prdct/electro/pdf/technical/revtant.pdf
basically saying tantalums should never be designed in circuits where a
continuous reverse bias exists and since they fail to present a
definition of revers biased I find it hard to believe a microvolt is
going to do harm them. So whats the truth about using tantalum's in such
applications ?
small (< 50mV).
applications ?
