There are variable resistors on the main circuit board, probably on the
right side when viewed from the back of the set. One will be horiz size and
the other vertical size. However, if he vertical size has been changing it
is probable that components have changed in that circuit or in the power
supply to the vertical circuit. Inclusive are the electrolytic capacitors.
