M
Mike
a friend of mine gave me this TV if i could fix it, so i went ahead and got
it.
I try to power it on, the tv will cycle for a sec and shut off.
I checked the HOT, and it tests fine.
I also read that there are two to-220 regulators that typically go bad on
these, I went ahead and replaced the 7805, and the 7806 regulators.
The television still cycles.
I pulled the power supply back out and checked the diodes and voltages. The
secondary supply diodes test fine.
I checked the volteges on the power supply, the 113vdc test post tests a
normal voltage, and I checked the voltages at the regulators and they both
appear to be normal.
There is about 7volts on the 5vdc regulator with a 4.8 to 5v output
there is 11.5 vdc on the 6vdc regulator with about 5.8 to 6vdc output.
The volts are normal. When i try to power it up, it will cycle too quickly
for the HV to come up.
If i disconnect the TV deflection board completely from the circuit, it
still cycles.
Im stuck plz help.
it.
still cycles.
Im stuck plz help.
