Zenith TV Problem....Please Help
Discussion in 'Electronic Repair' started by Robotron Tom, Nov 27, 2004.
  1. Robotron Tom
    Robotron Tom Guest
    I mistakenly posted that I had a Toshiba. It is actually a Zenith, model
    SY3272DT 32" TV, manuf. May 1997.
    sound but it does not come on. No picture, no sound. It's the same with
    remote or button on the set itself. I looked and no light from the
    heater. It did come on, once after the set had been unplugged for about 3
    months, but hasn't since.
    Also, any source for a schematic for this set?
    Thank you,
    Robotron Tom *remove nospam to email*
    See the Flashback Arcade at: http:// www.arcadeguy.net
    Standing for right when it is unpopular is a true test of moral
    character.
    -M. Smith
  2. Brett
    Brett Guest
    The "coming up" sound you hear, do you mean the high voltage causing
    the screen to become electrostatic? What does it sound like exactly?
    Start in the power supply. Check CX3416 - 100uf, 25v. Seems to be a
    common problem with this model.
  3. Robotron Tom
    Robotron Tom Guest
    Brett started a controversy when he said... :
    The sound I hear is a click, very short squeal then another click. The
    entire sound duration is less than a second. I believe the squeal is the
    HV and the click is the relay. It sort of sounds like it tries to come on
    then nothing.
    I will replace that cap, should I replace it with a higher voltage rating
    like 100uf, 35v?
    Thank you,
    character.
    -M. Smith
  4. Robotron Tom
    Robotron Tom Guest
    Done...and FIXED!
    Thank you very much for your input.
    character.
    -M. Smith
  5. Brett
    Brett Guest
    I don't think replacing with a 35v cap will hurt. I have a list of
    other components known to go bad also. Let me know if this works. If
    not, I'll send you what info I have. Good luck.
