Zenith SY2568S Focus adjust?
Discussion in 'Electronic Repair' started by RickC, Dec 31, 2004.
  1. RickC
    RickC Guest
    Can someone tell me if the focus can be adjusted on the Zenith SY2568
    TV?
    The picture seems fine, but any text is out of focus. I was wonderin
    if there was a simple POT that can adjust this?
    Thanks in advance,
    Rick
  2. Guest
    There is a focus adjustment in the set. However, if bright letters and
    objects go way out of focus, you are looking at a bad picture tube.
    The SY line of 25" Zeniths are well known for early picture tube
    failures.
    David
  3. Jamie
    Jamie Guest
    one or tow reasons.
    To much contrast.,
    AGC some how is over loading.
    poorly regulated HV.
    Weak Picture tube. <<< most likely
