Zenith projection tv with convergence problem
Discussion in 'Electronic Repair' started by Al, Apr 30, 2005.
  1. Al
    Al Guest
    I have a 52 inch projection that I started having convergence problems
    just about 2 months after the warranty went out. I live in a area
    where the only repair is 40 to 50 miles away. We had a shop open up
    and I took the tv there and he said the convergence board was out. He
    kept the tv for about 4 months and never came across to get the board
    or repair.
    I have just curved lines on the screen now and see all the colors but
    they won't go together. This tv says on the back mfg 1997. I got it
    about 1999. It has been out for these 3 years or so.
    Here is my question. I have a friend that had what appears to be the
    same tv. His tv had a weak pix and the repair man came and turned up
    something to get a bright pix but said that it was at it's max. Then a
    year later this friends set went completely out.
    If the tv is the same as mine can I try myself to take the convergence
    board out and put his in. He says I can have it. Can some one tell me
    where the board is or what I am looking for.
    ANY AND ALL HELP APPRECIATED.
    If you reply you might also send me an email to my email address
    THANKS
    AL
  2. JANA
    JANA Guest
    If the TV is the exact same model, you can safely swap the board. If there
    are no faults with it, and no other faults in the set, it should work. You
    will have to do the complete convergence setup on the board, since it was
    set up to the other set.
    If you call a technician who is experienced with Zenith sets, and has access
    to Zenith parts, he should be able to properly service this for you. The
    only obstical that the tech may run in to, is if there are any specialized
    parts that have to come from Zenith only, and are no long available.
    Sometimes the fault are some defective components that are generic, and they
    can be purchased from most electronic parts suppliers.
    There are very few excuses for not being able to properly service this for
    you.
  3. If its the same model number as yours...grab ALL of the boards... spares are
    costly
  4. Guest
    All the boards, hv splitter and focus block, and the tubes.
    Not the highest quality set and parts are steep.
