Zenith Projection TV Heaters
Discussion in 'Electronic Repair' started by [email protected], Sep 13, 2005.
  1. Guest
    I inherited a Zenith PV5263RK that has sound and no video. I read a
    post to check the heaters. How do I check to see if the heaters are
    lit. Is this a visual inspection? What do the heaters look like?
    If there is a newsgroup that is better suited for such a question,
    please let me know.
    TV Model PV5263RK
  2. kip
    kip Guest
    Look at the lower section of the tube.
    If lit you should see an Orange glow.
    kip
  3. inti2
    inti2 Guest
    To identify the two heater pins check with an ohmmeter : they should read
    from 4 to 10 ohm.
    I.
