mark said:
How do you adjust the height on this set.
Zenith SR2053S 1995 20" model
I am only a beginner, but why does the height need to be adjusted? Has
the set been worked on, or did this gradually happen? Is the screen
short on top and bottom, or just on top? You can check the internet
for service mode/codes for your set. Chances are good you will find
it. You can access the horizontal and many other settings in this
mode. Be very careful, you can damage your set by changing the
preprogrammed info stored for some settings.
