Zenith 9" TV
Discussion in 'Electronic Repair' started by Chris F., Dec 13, 2006.
  1. Chris F.
    Chris F. Guest
    I need a very small bit of help on this.... the model # is missing (paper
    label long since fell off), and I need a model # to get a service manual
    from servicemanuals.net, since they cannot go by chassis or module. The main
    module is a 9-468, all I need to know is the model # for ANY Zenith set
    using that module, since that's where the problem is. Or if anyone has a
    copy of the 9-468 schematic itself that they could Email me, that would be
    great.
    Thanks for any advice.
  2. Guest
    Chris F. wrote:
    The main
    J0920X
    J0930X
    G0920A
    G0920X
    G0930Y
    F0920A
    F0930S
    The model number should also be on a tag stuck on the CRT
    David, on the Illinois prairie.
  3. Guest
    Try first by downloading Z-Tips:
    http://www.orpheuscomputing.com/technicians/tech_downloads.html
    You may even find a solution to the problem and not need the schematic.
  4. Chris F.
    Chris F. Guest
    Thanks for the info Dave. Servicemanuals.net wants $25 for the manual
    though, not worth it for a set like this. I don't know how these vendors can
    justify charging so much for manuals, given the low value of the sets
    themselves.
