Zener Diode
Discussion in 'General Electronics Discussion' started by EMC, Mar 7, 2017.
  1. EMC
    EMC
    5
    Mar 7, 2017
    what happens if zener diiode is connected in parallel before a resistor
  2. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    In parallel with what?
    Diagram?
    M.
  3. EMC
    EMC
    5
    Mar 7, 2017
  4. EMC
    EMC
    5
    Mar 7, 2017
  5. garublador
    garublador
    111
    43
    Oct 14, 2014
    To me that looks like the diode is just there to protect the PC0 pin from going above ~5V. Net SPEED_INP is getting divided in half, probably to comply with the voltage specs for pin PC0 and the diode is there as a safe guard in case net SPEED_INP goes above ~10V. At least that's why you normally see zeners used in that manor.
  6. EMC
    EMC
    5
    Mar 7, 2017
    got it.
    thank you!
  7. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    That would be my take also, just a 5v clamp for safety.
    M.
  8. Herschel Peeler
    Herschel Peeler
    401
    66
    Feb 21, 2016
    The Zener diode will regulate the voltage across the resistor, just as it is suppose to do.
  9. davenn
    davenn Moderator
    13,880
    1,964
    except there wont be any current limiting and the zener will die
  10. Herschel Peeler
    Herschel Peeler
    401
    66
    Feb 21, 2016
    Do you think the micro will put out more than 4.7 V?
