@SHAIK MAHABOOB BASHA : Welcome to Electronics Point!
This thread is (or was!) about zener diodes. It is considered impolite to jump into a thread with a new topic as you just did. This is called hi-jacking a thread. People do that all the time in forums, and I am guilty of it myself, but we should avoid it. In the future, please initiate a new topic title before posting.
However, since we are already here... zener diodes do not have a PIV (peak inverse voltage) because they are operated in a reverse-biased mode that intentionally
causes reverse breakdown at the zener voltage. Current limiting is required after the zener voltage is exceeded. In a normal diode, used as a rectifier, reverse breakdown (PIV exceeded) will generally result in failure of the diode because there is no current-limiting impedance in the circuit.
