Yusynth metaliser
Discussion in 'Audio' started by darren adcock, May 6, 2018.
  1. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Hi all, i'm looking for advice on what component values i may need to change on this circuit to run it at -12v / +12v rather than the -15v / +15v please?
    Best
    Darren
    [​IMG]
  2. (*steve*)
    25,291
    2,731
    Calculate the voltage on the base of Q3 from resistors R17 and R43. Changing R43 to 100k may be close enough.
    R21/R22 could be changed to 18k (likewise for all the other similar pairs of resistors).
    R5 and R6 12k. R18 15k.
    Is this for a eurorack mod synth module?
  3. kellys_eye
    kellys_eye
    4,277
    1,146
    Jun 25, 2010
    Note that the output op-amp is a rail-to-rail device (output can swing to either supply rail) and that if you require the output waveform to reach these levels (for onward voltage-control of anything) then you won't be able to.
  4. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    HI Steve, thanks, it's to go in a music from outer space system I've been building, well actually it is already in the system just i've been noticing some spiralous noises and quite a lot of undulating hum/distorted/noise coming from it at times and realised I hadn't paid enough attention to the fact it was designed to run on a different voltage, lazy really, just assumed it'd be fine..... electronics tends to not like my assumptions :)
    "Calculate the voltage on the base of Q3 from resistors R17 and R43"
    I hope i'm getting this right, in that i just use a voltage divider calculation?
    So here's my calculation based on original component vlaues
    15 (v) x 1.5 (R17) = 22.5
    120 (R43) + 1.5(R17) =121.5 22.5/121.5 = 0.1851
    So the answer 0.1851 needs to remain (or be as close as possible) when adjusting the divider accepting 12v and changing R43?
    And with R43 changed to 100K and voltage at 12v
    12 (v) x 1.5 (R17) = 18
    100 (R43) + 1.5 (R17) = 101.5 18 / 101.5 = 0.1773
    Is that close enough?
    Actually I stopped here and realized I should be able to calculate, I needed to get some help off a friend though to help me through the steps needed to isolate R43, the calculation needed is;
    V source x R17 / V out - R17 = R43
    12 x 1.5 / 0.8151 - 1.5 = 95.74
    As for the other pairs of resistors, i'm unsure how to calculate these, or at least what calculation is required? Maths is still very new to me, but trying my best to learn and catch up
  5. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Hey, thanks for your reply
    I hope i understand
    I don't need the output to reach the peaks to further control anything by voltage, the output is an audio out which usually goes straight into a filter.
  6. (*steve*)
    25,291
    2,731
    The changed I suggested probably aren't that important. I don't really know why Q3 is biased the way it is, but our of an abundance of caution I'd say keep it as similar as possible.
    The values I gave would be what I would start with.
  7. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Ok Thanks Steve
  8. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    I have other Yusynth modules i need to adjust. As I go though them and ask for advice is it best that I post in this thread or separately for each circuit?
  9. (*steve*)
    25,291
    2,731
    As long as they're all about converting synth modules from +/-15V to +/-12V then I see no problem.
    How did the first one go?
  10. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Cheers Steve, yeah i have three more to convert, plus future yusynth builds. It would be good if I can learn to read where reference voltage points (I'm guessing that's what they might be called?) are in the circuits during or by the end of this process and be able to apply some Math to the adjustments required.
    I move into a new workshop on Monday, will take me a few days to settle in and set up at which point I can begin changing the resistors. I'll report back as soon as I can with how it has gone.
  11. Harald Kapp
    9,633
    2,013
    Wouldn't it be easier to provide +- 15 V and leave the modules in their original state?
  12. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    I hadn't thought beyond having a single power supply, the "Music From Out Of Space" modules require +/- 12v, the "Yusynth" modules require +/-15v. I wanted to run them in the same system. Do you think it would be easier to provide both power buses throughout rather than change the modules?
  13. Harald Kapp
    9,633
    2,013
    You could use a +-15 V power supply plus a pair of 7812/7912 voltage regulators to create the +-12 V for the music module from the +- 15 V. No additional transformer or rectifier required, only the regulators and a handful of capacitors. Easy to wire on a piece of perfboard.
    The additional "bus" is but a pair of wires (ground is and has to be the same for both power systems).
    It's the way I'd go because I'm lazy ;D. Doesn't mean you have to do it that way. If you want to learn a bit about modifying ("hacking") the 15 V modules to work from 12 V you're welcome.
  14. (*steve*)
    25,291
    2,731
    In general there would be no problem supplying some modules with +/-15V and others +/-12V. In fact, most of the modules designed for +/-12V should not be damaged by +/-15V (not a guarantee).
    However, a module powered by +/-15V could supply an output voltage outside +/-12V to a module powered by +/-12V, and this might cause problems.
    It may be easier to look at the inputs (and outputs) of the +/-12V modules and see if they will be safe in such an instance.
    If you go this route, you will need to check any new +/-12V modules, including ones where you don't have the schematic.
  15. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Cheers Harald. Ok, I understand this and agreed it would be easier. I think for now i'm ready to learn how to modify the circuits as it will be a good learning exercise, i'm finding learning Math quite difficult and this might be a good place to begin trying to apply myself more.
  16. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Cheers Steve. Would this mean checking the Control voltage tolerances for each module? Or checking what CV each module expects to recieve? I.m pretty sure the MFOS modules expect -+/-5v and supply this also, I've driven some harder at times by mistake and haven't seen any problems, but then I'm unsure of how over time this might damage the circuit
    Also i'm guessing making sure there's no impedance problems between modules?
  17. (*steve*)
    25,291
    2,731
    It would mean checking the output voltage for all modules. Make sure it doesn't exceed +/-12V. If the inputs (of the +/- 12V modules) are protected by some series resistance or blocking capacitors then the chance of damage will be reduced.
  18. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Thanks Steve
  19. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    I'd gotten the power distribution incorrect in the entire system. I'd wired it all in series. Rewired it all today with a bus and all noise, spirilous sounds, popping disappeared. If I'd explained the problems I was having with my system and photos of how I'd wired it all I'm sure you'd have pointed my error out straight away. Apologies. I will still make the modifications to the YUSYNTH modules to adapt to +/- 12v. Good news is that my synth now sounds HUGE and wonderful :)
  20. darren adcock
    darren adcock
    463
    34
    Sep 26, 2016
    Not too make the original post redundant, just I'd thought the problems coming from the synth were because of me not supplying the YUSYNTH modules with the correct power. Works out it was me not getting 'power' correct in the first place.
Similar Threads
Loading...
