yet another mechanically scanned display
Discussion in 'Electronic Design' started by ER, Jul 17, 2003.
  1. ER
    ER Guest
    I would like to solicit help in reverse engineering a mechanically
    scanned LED display that I've seen in specialty stores such as the
    Discovery Channel store.
    As far as I can tell, the unit operates as follows:
    1. A column of LEDs sits on top of an arm made out of a springy metal
    (dimensions similar to a hacksaw blade). The base of the arm is fixed so
    the top of the arm with the LEDs can sway back and forth.
    2. Just below the column of LEDs on the arm is a bulk of metal which is
    probably a magnet.
    3. The arm is positioned between two parallel electromagnet bars which
    are about 6-inches in length. The bars are at the same height as the
    bulk of metal on the arm.
    4. There is a photo-interruptor positioned so it gets triggered by the
    moving arm, and the pulsing of the LEDs is controlled by a microcontroller.
    I imagine the thing works by energizing the bar electromagnets in one
    direction and then in the opposite direction to create an oscillating
    magnetic field. The field pushes and pulls on the arm's magnet making it
    swing back and forth. The springiness of the arm gives the arm a quick
    stop at the limit of its swing as well as helps to propel it on its
    return swing. I estimate the frequency of oscillation to be in the low
    tens of Hertz (10 - 20 Hz).
    One thing I eespcially like about this mechanically scanned display is
    that there are no gears to jam up if you forcibly stop the arm. Indeed,
    it is safe to stop the moving arm with your finger.
    I'm just a computer guy so the microcontroller stuff isn't a problem.
    The questions I have relate to the design of the electromagnetic
    subsystem. Specifically,
    1. Does my theory of operation have a chance of working? After all, the
    magnetic field along the length of a bar magnet is much weaker than at
    the ends. Is it possible that the two bars actually form a U-shaped core?
    2. What kind of parameters should I be considering for the design of the
    electromagnets? If possible, I'd like to use something like a 12V/1Amp
    power supply, although my prototyping suggests that this won't be
    powerful enough. What about using an AC-powered (120V/60Hz)
    electromagnet? Has the potential of killing two birds with one stone
    since the oscilliation would be taken care of by the power company.
    (Yes, I know it also has the potential for killing myself, although
    there are AC electromagnets in many household appliances, so I know they
    can be safely made.)
    3. Are there any other considerations I should be aware of when
    generating these fluctuating magnetic fields (such as telling friends
    who have watches with expensive Swiss movements to stand back.)
    All help will be appreciated,
  2. It would be operating at a (mechanically) resonant frequency. The
    magnets are almost certainly not strong enough to yank that springy
    bit over, but they *are* strong enough to feed in the little bit of
    energy that's lost to air resistance and heating of the spring.
    You probably have to start it that way too.
    Most likely. Maybe a permanent magnet at the end of the arm and a
    U-shaped core, although it could be done with ferromagnetism. If it's
    ferromagnetic, you would just have to energize the coil for a bit as
    it approaches each pole of the core. Polarity could be the same for
    each end of travel.
    Best regards,
    Spehro Pefhany
  3. Mathew Orman
    Mathew Orman Guest
    If I am inventing or designing something I would like to know
    if someone did it before.
    And I am shore that OP would like to know that too!
    Sincerely,
    Mathew Orman
    www.ultra-faster-than-light.com
    www.radio-faster-than-light.com
  4. Ben Bradley
    Ben Bradley Guest
    I wouldn't think so. Pulses into the electromagnet at the
    approximate resonant frequency should be enough to get it oscillating
    with enough amplitude to trigger the optointerruptor.
    Since, as Spehro points out, this is surely a mechanically resonant
    system, it really only needs a short pulse in one direction from the
    electromagnet. This will pull the thing offcenter, and it will then
    swing back the other way, and then back again, in a damped sinewave.
    Just giving pulses at the right frequency will get it swinging back
    and forth.
    With a resonant system, this should be more than powerful enough.
    You're getting this thing to swing much like a pendulum in a pendulum
    clock. The mechanical components (the thin piece of metal as the
    spring, the mass of the arm with LED's) move the mechanism back and
    forth, while the electromagnet only has to supply enough energy to
    overcome frictional losses.
    This mechanism works much like the electromechanical
    battery-powered clocks from (I think) the '60's. Maybe someone else
    remembers these and can give a description.
    Don't use AC. Use 12VDC and switch it on and off with the
    microcontroller. You don't need to wind it yourself either, you can
    just use the coil out of a relay.
    If you put it next to or ontop of a traditional CRT-based TV or
    computer monitor, it may interfere with the picture on the screen, but
    other than that it's no worse a source of fluctuating magnetic fields
    than an operating CRT. It's probably a lot less.
  5. ER
    ER Guest
    Here's the issue I'm running into... 40 ft. of #28 gauge magnet wire has
    a resistence of 20 ohms, so a 12V supply will give me .6 Amps. According
    to my preliminary testing, this isn't powerful enough. I haven't yet
    tried tweaking the mechanical side -- maybe I'll try that next. As for
    making the electromagnets stronger, besides increasing the voltage, the
    only other way I can think of is to wrap another coil around the first
    so I am drawing double the current. Are there any pitfalls to this
    approach? Or, would it be better to re-wrap the coil with th two strands
    next to each other? In this case the turns/inch locally is halved, but
    overall it is doubled since I'm going back and forth over the same
    6-inch bar with two strands instead of one. Or maybe that's not the way
    the math works...???
    Exactly, and you don't need to start it by hand. When it's free to move
    at rest, the arm quickly attains its maximum amplitude within a few seconds.
    Okay, I'll hold off the AC. :)
  6. seconds.
    [snip]
    FWIW, a while ago I bought such a clock, but wanted to change the fixed
    messages. It runs on a PIC16F674, and when I had it apart, I did some
    measurements as to find out what pins did what. I noticed that during
    start, the coil is pulsed at a varying frequency, where it tries to
    find out the resonance of the mechanism. The inital movement is rather
    small, then increases until the arm passes the sensor, and from then
    on the frequency seems fixed. The PIC code was protected, had no strong
    desire to write it all from scratch, so I reasembled it and gave it to
    my brother, as a present.
    It is a bit marginal designed, for instance, if you place it on a
    soft surface, like carpet, it's not able to 'tune' itself into
    succesful swinging.
  7. Doesn't seem like you need to build an AC magnet operating at 110 V.
    Seems like it would be best to go to 24 V or 12 V and build a
    programmable pulse generator. That way you can control the stroke
    length, acceleration, and speed by varying the shape of the pulse.
    You'll need some magnetic field sensors like a Hall device along the
    path of the piston for feedback to your central processor. You can
    control the vibrations by using multiple coils and programming the
    controller appropiately.
    This is very similar to the controls for a pulse tube cooler.
    Using FPGs and switching power supplies the controller shouldn't weight
    more than a pound and might fit all on a medium size pc board.
  8. Wade Hassler
    Wade Hassler Guest
    Seems that way: the demo clock at Fry's would just sit there if you stopped it.
    (Fry's! The time and money I've pissed away there!)
    Wade Hassler
  9. The OP said in his first line or so he was reverse engineering an
    interesting bit of hardware. Really a demonstration of persistence of
    vision. Now be nice and go back to hunting for a sucker for your FTL
    garbage or selling some stupid idea about particle accelerators. In any
    event, it would be nice if you would go back to proving how incompetent
    you are at physics and stop explaining things that everybody knows but
    is not interested in because of context. You might give my signature a
    read while you are about it.
    Chuck
