I found a video on YouTube about the same model and symptom im having. The contacts on the same relay were dirty causing the receiver not to power up just like mine. So i opened the relay on mine and i cleaned the contacts. It turns on now, but it shuts off after 4 seconds every time i try it. When i power it on, the display has no warning message or anything like that, it just shows its in the FM stereo mode and then it turns off.
Im gonna buy a new relay, but i have a feeling there must be something else wrong in the receiver that is causing it to shut down.
Do you think its just the relay not making a good contact? I noticed on the board next to the relay it says "Short Relay" between two jumper wires. Is that for troubleshooting the relay im having problems with? If yes, do i just short it out with some alligator clips?
