Yamaha RX-V675 stopped working after thunderstorm
Discussion in 'Troubleshooting and Repair' started by Mauricio Calgaro, Nov 21, 2017.
  1. Mauricio Calgaro
    Mauricio Calgaro
    Nov 21, 2017
    I have a Yamaha RX-V675 and the unit turns off after 5 seconds (circuit protection on). My error code that the unit shows is like this "DC PRT 255H". Seems to be an abnormal DC output (high in this case) from the main power supply. Could you give me some help? Thanks in advance.
  2. kellys_eye
    kellys_eye
    4,316
    1,165
    Jun 25, 2010
    Do you have any test equipment (multimeter)?
    Browsing the technical manual ( https://www.manualslib.com/manual/1233924/Yamaha-Rx-V675.html#manual ) seems to show the majority of supplies being for digital levels (5V, 3.3V, 1.8V etc) and if any of these have gone 'high' then expect some potentially serious damage....
    Still, the first thing to do is to check for all the main supply voltage levels.
  3. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    It could be an error stored in the CPU that is causing this. Try the reset procedure to see what happens:
    1. Set the unit to Standby by pressing the Power button.
    2. While holding down the Straight button, press the Power button.
    3. SP IMP. 8 Ohm Min (Or 6 ohm) will come up on the Front Panel.
    4. Press the Right Program Arrow button repeatedly until INIT-CANCEL comes up.
    5. Press the Straight Button repeatedly until INIT-ALL comes up.
    6. Press the Standby button to turn off the receiver.
    7. The next time the receiver is powered on, the factory settings will take effect.
  4. 73's de Edd
    73's de Edd
    3,254
    1,364
    Aug 21, 2015
    Sir Mauricio Calgaro . . . . .
    With that unit staying on long enough for you to be able to get that display panels error display I believe that your problem is being in a completely different area.
    I am placing both the component and foil side "snippets" below of the concerned board of interest.
    This will just be a NO POWER APPLIED test . . . with you just using a DVM in its ohms function mode, lowest range.
    SET up and initially note the instruments display produced for a no connection / open circuit condition by its display shown when the meter probes are being unconnected.
    Then short the probes together and note that display read out . . . . . that will be our type of reading of interest.
    Now whichever board side is the easiest to get your probes to, note the two RED circles that are on the extreme outer ends of a transistors possible 3 connections..
    Work across those like 2 connections on each of the 14 side by side power transistors across the board.
    You are looking for any shorted ones.
    Standing by . . . .
    CIRCUIT BOARD REFERENCING POWER TRANSISTOR LOCATIONS . . . . .
    [​IMG]
    73's de Edd
