Yamaha RX-V 657 comes on then goes off
Discussion in 'Troubleshooting and Repair' started by jmm83, Apr 12, 2018.
  1. jmm83
    jmm83
    3
    Apr 12, 2018
    Hi
    I have a Yamaha RX-V 657 that i bought from goodwill for $5
    when the power button is pressed it comes on for 2 seconds and then goes off
    when i tried it with a dim bulb test it came on and stayed on but the bulb was lit a little bit
    so i think there is a short somewhere
    when plugged into the dim bulb tester i did try the speaker outputs using the tuner and they all worked so i don't think it's any of the transistors on the amp board
    when i tested the CB354 connector on the power supply the voltages were low and when i unplugged the connector and tried to power it on it came on for one second and went off but the bulb did not glow that time. so im thinking it must be something on the power supply board or maybe the transformer
  2. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    So the units working then? or are you quoting this wrongly?
  3. jmm83
    jmm83
    3
    Apr 12, 2018
    it's working when it's plugged into the dim bulb tester
    but when plugged straight into the power outlet it comes on for one sec. and then goes off
  4. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    Is there a dual voltage setting (120/240)?
  5. jmm83
    jmm83
    3
    Apr 12, 2018
    no i don't see one on the back
  6. adir figueiredo
    adir figueiredo
    3
    Apr 18, 2015
    eta aparecendo que tem canal em curto
