- Joined
- Nov 17, 2011
- Messages
- 13,700
On behalf of Joe:
Hi, I have been going around in circles with my latest project a yamaha emx 660 mixer amp. I sorted out the obvious problems to start with some diodes, a couple of output trannys. I also replaced the voltage regulators 7815 & 7915 which should, I believe, work as a pair. All screwed back together onto the heatsink and main fuse blew again. Replaced fuse and using my trusty 100 watt light-bulb short-tester got a healthy glow. Unscrewed the output trannys from the 'sink and still the bulb glowed. When i unscrewed 1 of the VR's the bulb went out. Replaced both again and screwed back down, bulb glows. So set about tracing diodes backwards to power supply - ALL ok. Powered the amp up again, leaving VR's unscrewed from heatsink and works a treat. I can screw either down to the heatsink and not get a short but with both a short occurs. Both are reading -ve from the case and normal from respective pins.
What am I missing or should I just insulate 1 before screwing down.
I am a hobbyist with some knowledge of this particular amp board but the first of about 15 I have rescued with this fault.
HELP !, and Thanks in advance.
Joe
Joe
