samuel phillips
- Jul 3, 2017
- 41
- Joined
- Jul 3, 2017
- Messages
- 41
Hi guys been trying to find the problem on this one but to avail i need help before my brain gets toasted. so to run down is all the voltage test are ok. i found some bad cap i replaced them. So the owner told me that a few months ago they turned it on and heard the same static and popping sound, they would leave it on for a bit and then the static and popping would die down.
Then the piano would work like normal, they ran so for a while, until now that is all you get static and popping from the speakers. i tried running the test program and it freezes. On a cold start up the lcd freezes and no functions work sometimes on start up the lcd is blank but after while of staying on you get functions but no sound from keys only the static and popping. I know this instrument is old but i would like to help them get it up and running again. i'm all ears as to what could be the issue here. Here is a link for the service manual.
(http://mharding.net/wp-content/uploads/2017/01/yamaha_clp-150.pdf)
