Yamaha cd player spindle problem??
Discussion in 'Electronic Repair' started by TJB, Mar 6, 2007.
  1. TJB
    TJB Guest
    I'll just measure it with calipers. I was hoping someone would have the
    correct measurement from a manual, as I am concerned about the plastic
    locating lug height being a problem.
    TJB
  2. It's just been my experience. The original was pressed on with a machine.
    You and I press it on by hand and it doesn't wind up that the disc will
    rotate quite as flat as the original once the job is done. Like I said, it;s
    not really a big deal. The focus servo will just have to work a little
    harder.
    Mark Z.
  3. TJB
    TJB Guest
    Thanks Mark. I will order a motor and see what happens
    TJB
  4. TJB
    TJB Guest
    Just fitted a new motor. Can't tell if it has more wobble or not. I
    don't have any way to measure the wobble but from an 'eye ball' point of
    view, it doesn't seem to spin all that flat, (orig may have been the
    same). but the focus tracks the cd and the unit plays just fine.
    Thanks everyone for your help
    TJB
  5. Woo-Hoo!
    Glad that worked out for you.
    Mark Z.
  6. TJB
    TJB Guest
    Thanks Mark, I still have this uncomfortable feeling about that
    turntable locating pin. If the laser assembly springs start to sag any
    cd you play will start to rub on this pin; there seems to be just over
    1mm clearance. Oh well I will just have to see what eventuates.
    Cheers
    TJB
