Xport teardown
Discussion in 'Electronic Design' started by John Larkin, May 5, 2007.
  1. John Larkin
    John Larkin Guest
  2. Jim Thompson
    Jim Thompson Guest
  3. Michael
    Michael Guest
  4. Jim Thompson
    Jim Thompson Guest
    Most likely it's just a custom ASIC.
    ...Jim Thompson
  5. Me too, thanks.
    Best regards,
    Spehro Pefhany
  6. John Larkin
    John Larkin Guest
    OK, up on abse.
    John
  7. Jeff L
    Jeff L Guest
  8. John Larkin
    John Larkin Guest
    I know that. I just wanted everybody to beg.
    John
  9. I didn't see it there, where is it, where is it?
  10. John Larkin
    John Larkin Guest
    Posted to abse yesterday.
    John
  11. John Larkin
    John Larkin Guest
    Have you seen the same thing, high power consumption and high case
    temperature, for no reason? Lantronix told us they'd never seen it
    before.
    John
  12. LVMarc
    LVMarc Guest
    Helo John,
    I use these beasts in a building network scheme. Some do go ballistic
    for no good reason as you mention. Never took one apart (so carfeully)
    and pictured so well. Nice work!
    marc
  13. LVMarc
    LVMarc Guest
    Yeah we saw it suck cuurent and act flaky, we had a net work of 3
    lantronix rs-485 to ethernet, all the thernets back to a pc. we buffered
    the drive signal from the lantroinx to drive rs-485 using "cp1" to
    select drive enable. on random times wewould get data failures, have to
    re boot and would work fine for 100's of hours. then fail ususally hot.
    we used curent limitng power supplies so we could see when the beasts
    failed. considering another source for that function and eliminating
    the rs-485 to ethernet bridging entirley...made sense for using exsitng
    wiring at first..
    Marc
