XM Radio Antenna Question
B
Buck Turgidson
Not sure if this is the right place to ask, but I am wondering what sort of
antenna is required for XM radio in a home? I cannot receive DirecTV, etc
due to a tree canopy surrounding my house, so I am wondering if I would have
the same problem with XM Radio.
Thanks for any replies.
G
Gary
More than likely you would experience similar results. Though an XM
receiver is more omnidirectional, it still is fed from satellite and you
need a pretty clear path to receive it clearly.
GLW
Joel Graffman
XM radio is more tolerant to obstructions than DirecTV. My XM antenna is
inside under a tile roof and works fine. I did have to play with the
location and it doesn't work everywhere in the house. I use the standard
house antenna.
You can try XM without subscribing, I expect most places will let you return
the unit if you can't make it work.
M
Mike S.
XM is still limited by large obstructions but you are likely to have more
luck than with DirecTV. XM has _two_ satellites, plus terrestrial
repeaters in many metropolitan areas. You only need good signal on one of
the three possible sources to get acceptable reception.
If you get a dealer that accepts returns, buy an XM receiver and try it
out. You get free reception on a few preview channels without any sign-up
or obligatiom; just hook it up and turn it on.
