XLR Connector Ampacity
Discussion in 'General Electronics Discussion' started by volksman33, Jun 26, 2011.
  1. volksman33
    volksman33
    Jun 26, 2011
    Does anyone know how much current can be pumped through a single pin on a 5 Pin XLR connector? thanx
  2. daddles
    daddles
    443
    3
    Jun 10, 2011
    No, but you can estimate it by some measurements. A few months ago I did this for BNC connectors, as there are no specs for BNC power dissipation (i.e., the actual power you can dissipate in the connector). The pins, sockets, and pin-to-socket connection's resistances will be down in the milliohm or sub-milliohm region. The limiter of the connection is probably the wire that is used in the connector, not the connector; this is the case with the typical RG-58/U coax used with BNC connectors. Get a constant current power supply and measure the temperature rise of the connector body with an IR thermometer as a function of current. Use your engineering judgment as to what's an acceptable temperature rise. For the BNC/coax, I decided that I would limit my BNC cables to 5 A continuous DC current, but would allow 10 A for short periods (say, a minute or two).
  3. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    If you're referring to the good old "massive" pin with solder bucket types then here are some common/ general spec's:
    Rated current per contact @ 35°C:
    3 pole: 16A (max 12 AWG)
    4 pole: 10A (max 16 AWG)
    5 & 6 pole: 7.5A (max 18 AWG)
    7 pole: 5A
    Contact resistance: ≤ 3mΩ
    Rated Voltage: 50 or 250V AC (depends on brand)
    Switchcraft brand seems to be rated a bit lower:
    Current Rating (Carry Only): 5A, 125 VAC (4A, 125 VAC on 5 circuit) based on 30°C maximum.
  4. shrtrnd
    shrtrnd
    3,816
    518
    Jan 15, 2010
    Check with the manufacturer, they'll have the rating.
