Xbox 360 woes
Discussion in 'Electronic Repair' started by N Cook, Jul 12, 2007.
  1. N Cook
    N Cook Guest
    Strange seeing this technical stuff in a national newspaper today
    http://technology.guardian.co.uk/games/story/0,,2123720,00.html
    Where the Xbox 360 went wrong
    Whoops, there is a problem with the console failing in significant numbers
    after all, said a reluctant Microsoft this week. So what is the cause?
    Charles Arthur investigates
    Thursday July 12, 2007
    snip
    So what are the causes? Owners and analysts have made their own
    investigations. The most obvious suggestion is that parts overheat; the Xbox
    360 draws 160 watts, which has to be dissipated via two large heatsinks and
    two fans. One suggestion is that when the machine gets hot, the motherboard
    warps and pushes the graphics processing unit (GPU) off its board. Another
    is that some of the soldering is imperfect and so cracks at high
    temperature. A Microsoft support document also suggests, improbably, that
    surge protectors and extension strips contribute to the problem by
    preventing the current surge needed for the fans to turn on; this seems
    unlikely, since that surge would be too small to trip them.
    In desperation, some owners have turned to home-grown cures - including
    wrapping a towel around the machine, blocking the fan vents. This may -
    depending who you believe - either cause the solder to reflow or the GPU to
    reseat. (Microsoft has not commented.) The fixes sometimes work, at least
    temporarily.
    We can deduce some of the reasons from the fact that Microsoft is declaring
    that the problems are sorted out - just as it is moving from 90-nanometre to
    65nm chips, which should reduce its power consumption significantly, and
    using a two-part heat sink in the new designs.
    snip
  2. Eeyore
    Eeyore Guest
    Bad thermal design.
    I hate to think what'll happen when the fans get worn out and the heatsinks get
    full of fluff too. They could be fixing these for a long long time.
    Graham
  3. Ron(UK)
    Ron(UK) Guest
    What beats me is how these problems don`t show up in early pre
    production units! They get hundreds of thousands of units on the market
    before anyone notices that they overheat!
    Ron(UK)
  4. Eeyore
    Eeyore Guest
    I rather imagine they didn't do any proper testing.
    Of course an experienced designer would have been looking out for this. Either
    they're not using experienced designers or the suits decided they knew better, which
    is entirely possible.
    Graham
  5. James Sweet
    James Sweet Guest
    My roommate has one, which is still working thankfully. When it heats up, it
    sounds like a jet engine, and it will raise the temperature of the room by
    several degrees if it's left on long. Amazing how much heat it kicks out.
  6. JW
    JW Guest
    *Guffaw!*
  7. Eeyore
    Eeyore Guest
    Quite.
    220C internally ? I think not.
    Graham
  8. What do you expect from anyone who would buy an Xbox, in the first
    place?
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
