Xantrex DR2412 inverter/charger?
Discussion in 'Photovoltaics' started by Old & in the way...., Sep 26, 2006.
  1. I need to upgrade my system, especially the charging function. This Xantrex
    model has the features I want, but how do they hold up under use? Any known
    problems? Failures?
    brian
  2. Thanks for the information guys.
    The DR's cost is about as high as I can go on this part of the system. Given
    that my Tripp Lite now runs everything that I use (comp, TV, Sat Microwave)
    and the DR would be even better and has a good rating here I will go ahead
    and pull the trigger on this purchase. This application is only used a few
    months a year so I can't justify spending more and UL or not is not a
    problem.
    A question: This disconnect that you talk about, is it something like the
    old knife switch? Or is it automatic, relay based? What brand/kind should I
    be looking at? Costs?
    Thanks, brian
