X10 PL513 cable?
Discussion in 'Security Alarms' started by Mach 1, Feb 24, 2005.
  1. Mach 1
    Mach 1 Guest
    How is a cable to use on the PL513 interface different than a standard
    phone cable?
    Something to do with 1 to 1.
    I thought a phone cable was 1 to 1.
  2. I found this really old file on my computer, dunno if it's still applicable:
    The cable required for the Pl513 module is shown below. It is made
    of 4 wire phone cable, an RJ-11 connector, and a DB 25 pin male
    connector.
    Black
    Select 17 o-------------------------------o 1 Zero
    Input Red Crossing
    Common 18 o-------------------------------o 2 Common
    Green
    Common 19 o-------------------------------o 3 Common
    Yellow
    D1 3 o-----+-------------------------o 4 Signal
    | Input
    D3 5 o-----+ Jumper 3,5,7,9
    | together
    D5 7 o-----+
    D7 9 o-----+
    Male DB25 Connector RJ11 connector
    For Printer Port For PL513
  3. alarman
    alarman Guest
    Mach 1 wrote
    The cable used with the x-10 interface modules is a straight-through or
    patch cable. A standard telephone cable is a crossover cable.
    js
  4. Mach 1
    Mach 1 Guest
    Thanks Gordon. I should have mentioned I need the RJ11 connectors on
    both ends.
    Im using the PL513 with a Visonic alarm.
    So if you were to take the RJ11 connector off the end of a phone cord
    and turn it over it would be straight thru. Right.
  5. sorry. i don't mess with x10 stuff anymore, i just had that on my 'puter...thought it might help.
  6. alarman
    alarman Guest
    Mach 1 wrote
    Right.
    js
