WT: schematics for Viewsonic VX910 LCD
Discussion in 'Electronic Repair' started by Pinballer, Feb 8, 2007.
  1. Pinballer
    Pinballer Guest
    Veiwsonic VX910 LCD monitor
    If anybody has these schematics or nows of them on line I am trying to find
    the part number for D660 on the power board. I've had a few suggestions and
    I appreciate it but I'm still stuck.
    If worse comes to worse I could try a suitable part (believe to be a dual
    diode) if anybody has any suggestions on a replacement.
    If she blows she blows, oh well.
    Thanks people
    Brian
  2. Franc Zabkar
    Franc Zabkar Guest
    Can you upload a photo of the PCB to your web space?
    - Franc Zabkar
  3. Pinballer
    Pinballer Guest
    I don't have any webspace but I could email you a pic of it. I have the pcb
    out of the monitor.
  4. Franc Zabkar
    Franc Zabkar Guest
    OK, do that and I'll post it on my web space for others to look at.
    - Franc Zabkar
  5. Meat Plow
    Meat Plow Guest
    Http://tinypic.com
  6. Guest
    markings on D660:
    LT428
    and
    MBR10100Ct
    outside pins are grounded, middle pin has 12volts on it.
  7. Pinballer
    Pinballer Guest
    WOW. Thankyou very much.
    Now to find the part.
  8. Meat Plow
    Meat Plow Guest
  9. Guest
    Replace the caps that are around D660. thats what was wrong with the
    one i have on my bench. (2) 470ufd at 25v...also there is a 330ufd
    cap
    wrapped in a sleeve not far from that..replace it...as far as your
    diode,
    if you can find the original, NTE lists a replacement for MBR20100CT.
    Not sure if its the same, but might be worth a shot.
  10. Pinballer
    Pinballer Guest
    I went and ordered the diode from my local electronics shop but its going to
    take over a week to get it. Thanks for the tip about the caps too. I will
    probably do them as well.
