[email protected]
John said:The problem with using transmitter tubes like 813s is the huge, 2500
volts here, B+ supply. You need a monster, custom, high-ratio, 5KV
insulated output transformer, and it's hard to get good HF response
from that.
from that.
John
I was wondering where they get the transformers??????
They must be custom made and very costly. The power transformers
might be made for large transmitters, but the output xformers almost
have to be custom made.
Just curious why the HF response would be poor? Is that due to the
thickness of the insulation in the xformer?
I have some 4-1000Z tubes around here. Some new, some
John said:The toob side impedance is high, so winding capacitance starts to
matter. And the HV insulation encourages leakage inductance.
Oh yeah, used to make CB amplifiers out of them in my younger days, somePhil said:Those were 6KD6 or the European equivalent? There were a lot of
sweep-tube linears built over here in the 70s. Some of them were even
passably linear.
Cheers
Phil Hobbs
where mobile
but at max 50KHz pwm I doubt it will do full audio range
frequencies
something like this: http://www.cadaudio.dk/d2404asw.pdf
2400W@4R 20-20KHz, 9.8" x 6" x 1.8" with power supply
list price 309euro ...
D from BC said:MSA260 Variable Switching Frequency PWM Amplifier
9000 Watts
6.6" x 9.8"
http://www.cirrus.com/en/products/msa260.html
Just add power supply.
What about the amplifiers that modulated the carrier of a 50kW AM
passably linear.
Cheers
Phil Hobbs
Push-pull parallel 807s?
Rich Grise said:Don't use 813's, if you want some REAL POWER!
http://w5jgv.com/4-400A_600M_amplifier/4-400A.pdf
Cheers!
Rich
Cheers!
Rich
John said:Glass envelope, air cooled, tungsten anode... Amateur.
Try this
http://www.cpii.com/docs/datasheets/78/4CM2500KG June 2011.pdf
Tauno said:EL500, EL504 and EL509. They put plenty of oomph with 600 V on anodes,
and many could be run as zero-bias triodes by paralleling grid and
screen. The grids needed some resistors to ptotect them from excessive
dissipation from the drive.
Try this
John Larkin said:Neat. 10 kilowatts for the filament alone.
But audiophools would prefer glass, so they can see the stuff glowing
inside.
John
