Would this simple circuit work?
Discussion in 'General Electronics Discussion' started by SkyKonig, Oct 24, 2016.
  1. SkyKonig
    SkyKonig
    6
    Jan 26, 2016
    Would this 3 pin rocker switch work without the 3rd pin connected to anything? So if i flicked the switch up the LED would come on, but the switch wouldn't turn anything on. Thanks guys :)
  2. davenn
    davenn Moderator
    13,798
    1,939
    well, for a start, the switch and battery has to be connected to some other circuit
    for us to help you more, we need to know more about the switch and its contacts .... do you have a link to a datasheet or similar ?
  3. KTW
    KTW
    273
    15
    Feb 22, 2015
    You could be shorting your battery with that.
    It's possible you have a switch like this which is on from left or right and off in the middle.
    You can test it with a meter if you have one.
  4. AnalogKid
    AnalogKid
    2,482
    715
    Jun 10, 2015
    If the LED is built into the switch bezel, it usually has separate pins. Photo?
    ak
    hevans1944 likes this.
  5. ramussons
    ramussons
    374
    71
    Jun 10, 2014
    LED, not Battery :D
