http://www.musicfromouterspace.com/analogsynth_new/SAWTOTRICONVERT/SAWTOTRICONVERT.php
really need a ramp to triangle converter for integrating into the MFOS Noise toaster.
I would of course prefer to stick with MFOS designs for assurance that it is 'musical grade'.
So any Ideas if it would be possible?
With my limited knowledge I know there is slight possibility it will work without modification- explanation:
The TL084 will function with as low as 7v (+/-3.5v) and the ramp input is from another OpAmp running on 9V (noise toaster)
obviously im not taking into account the bundle of resistors and caps (power supply filter caps seems like the most obvious problem)
