Jonathan Montoya
Hi, I've done a couple microcontroller projects, but otherwise I'm
pretty new to electronics. I recently bought an antique typewriter
that I'd like to automate for fun. My idea is that I could mount
solenoids under each key(which are essentially levers that push up on
some rods) and pull down with the same force that it would take press
key. I haven't measured how much force is necessary yet, and the
stroke is probably about an inch.
Before I started doing some expirements, I wanted to ask the experts
to see if this is at all feasable. Would solenoids be the best way to
do this? I picked them because they seemed like they'd better be able
to simulate the fast sharp action needed to get the antique key to
impress the ink on the paper. Will I be able to jam 50 or so of these
parallel and under the keys (given that they'll be mounted under a
desk or something like it), or will the size for the work needed
require more creative mounting? And, am I assuming correctly that I'd
have to make these myself, since they probably have speifications
different from what most solenoids are made for?
I appreciate any guidance I can get.
Lonlaz
Lonlaz
