Worth it to repair Tek 465 scope?
Discussion in 'Electronic Repair' started by John, Aug 27, 2003.
  1. John
    John Guest
    The primary AC fuse on my old 465 keeps blowing, heard this might be related
    to bad rectifiers or caps in the P/S. I don't know if it pays to have a
    local shop diagnose and repair it, especially since I've seen working 465's
    selling on Ebay for $200-$250. Any thoughts would be appreciated. --- John
  2. Bart Wessel
    Bart Wessel Guest
    John,
    Don't know about a local shop, but I'd advise you ta have a quick look
    yourself. A visual inspection might tell you if you have a really bad
    cap that's already leaking, next use a multimeter to check for too
    much AC present across the big caps.
    And yes, it is worth it, because you might by one from eBay for $200
    and run into the same problem again shortly - they are the same age as
    yours.
    My 2c.
    Bart.
    There may be a 'NOSPAM.' (mind the dot!) in front of my E-mail address.
    It is there to fool machines, not people. Please remove it when you want to reply to me personally.
  3. Jim Yanik
    Jim Yanik Guest
    I'd get out my DMM and ohm the rectifiers for shorts.Not that hard to
    do,and easy and economical to replace a bad one.And looking for leaking
    electrolytics is not too hard,either.
    After all,you know the basic condition of your scope;what you get off Ebay
    will be an unknown for some time,until it proves itself.
  4. James Sweet
    James Sweet Guest
    Definitly hold onto it and consider fixing it, parts such as the CRT are
    very difficult to find.
