the idea I have is to design a lifter device that utilizes the
biefeld-brown effect and is contained in a (relatively) pure
environment of Sulfur Hexaflouride (SF6). According to the research
Well, as far as I understand it the Biefeld-Brown effects relies on the
corona discharge (to create the ion wind) at the smaller electrode,
appearently the top wire in those "lifters". SF6 basically prevents any
corona discharge from happening (at least at moderate HV levels below
several 100 kVs or so). Provided my understanding of the Biefeld Brown
effect is correct, embedding the whole "lifter" in SF6 will actually
make the effect vanish or at least reduce its strength.
Encapsulating only the electrodes and filling it with SF6 or whatever
dielectrics may allow you to increase the breakdown strength, but in my
opinion you also make the Biefeld-Brown effect vanish, because any
enclosure around the electrodes isolates the ion winds mechanically from
the environment - hence no thrust at all will be generated. Besides that
I don't think that this will work at all, the requirements for the
material you are looking for are quite simple. There is no magnetic
field involved in the Biefeld-Brown effect and the electric field is
just an electrostatic field. To fulfill your requirements look for an
insulator with high breakdown voltage and long term stability and a the
lowest possible relative permittivity (in case you require maximum
"transparency" for the electrostatic field, which by the way makes the
use of SF6 questionable).
that I've looked at, if I maintain an internal pressure of approx 5
atmospheres, or roughly 73.5psi of SF6 the electro-conductivity of the
environment should be reduced to about a tenth of dry air (at sea
Well, only if the SF6 is dry. When you buy SF6 it usually still contains
quite a bit of water - do you have the equipment to dry it?
Klaus
