- Joined
- Jun 21, 2012
- Messages
- 4,886
You could add the little light in parallel with the heat cord so both come on at the same time. Maybe even use a higher wattage bulb. Maybe blow air across a large light bulb and use that instead of a heat cord. Lots of ways to make warm, dry, air. Back in the day you could buy nichrome heaters wound in a spiral about a ceramic cone that had an Edison base so you could screw it into a light socket. Made a pretty good heater. Kinda dangerous though... fire hazard, burn hazard, electrical hazard with that exposed heating wire. Probably can't even buy them anymore without a ton of paperwork.theres no way to know if it still flickers with just the heat cord
