Hi there,
I have a project, in which I am building a DC current supply and I am using a panel ammeter for monitoring, however the Chinese ammeter doesn't allow me to use power from the same DC supply to work (When I tried it, the ammeter gets crazy measurements), meaning that it doesn't accept being fed parallel by the same power source that is measuring in the other leg of the circuit, is there a way around this? perhaps a 1:1 transformer isolating coil to supply the ammeter?
My idea later on is to make my own ammeter built-in, to measure the current out put, however it has to work using the same power supply. Anyway, if anyone have a good and simple accurate ammeter circuit to share, please send me the info, I will appreciate very much.
Thank you
Thank you
