Jim Sumpter
I am finishing the wiring on my DSC 832 and am ready to jump into
programming. The manual states that I can set it up as being either a
NO or NC system, but has nothing in it about using both NO and NC
devices simultaneously. There is a diagram about using EOL resistors
showing both NO and NC contacts on the same zone, but in my case, that
didn't help at all. All of my devices are NC except for my door
contacts, and I am using EOL resistors on every zone. I had planned to
wire the 3 NO contacts to 3 different keypads, with the contacts being
the only device wired to the keypad zones. In the future, I would like
to wire some NO window contacts together on their own zone. So, my
question is, do I wire them up NO using an EOL resistor wired parallel
and not worry about the system being programmed as NC? I figured if I
did this it would constantly be in alarm. Also, for the window
contacts, would I wire them all parallel with a EOL parallel at the end?
I guess the resistor is the key to doing this? If the NO contact
closes, it would send the current through the 5.6k resistor, showing the
panel a violation. Hmm, did I just answer my own question?? Thanks in
advance for any tips you might be able to provide.
Jim
Jim
