Wiring Mistake
Discussion in 'Electrical Engineering' started by E. Hill, Sep 17, 2004.
  1. E. Hill
    E. Hill Guest
    The existing wire in my garage is 14 AWG.
    Lowe's accidentally sold me 12 AWG black and green, and 14 AWG white. I
    didn't notice until I got home.
    I went ahead and used the wire to install a new quad box with a GFCI outlet
    and a "load" outlet. Obviously, years down the line, if somebody opens the
    boxes, there's a discrepancy there. Should I redo the wiring?
    Thanks.
    Eric
  2. Sonco
    Sonco Guest
    your fine if its a 15 amp circuit.
  3. Bob Peterson
    Bob Peterson Guest
    Generally, you are allowed to use larger than required wire. Its a little
    odd and if it bothers you, pull the white wire and replace it with a larger
    one. Me - I would leave it as is.
  4. daestrom
    daestrom Guest
    14 AWG is fine if the 'protective device' (the circuit breaker feeding it)
    is rated for 15A. The largest circuit breaker size you can use is
    determined by the current capability of the most limiting component (with
    exceptions for some things like 15A recept. on a branch ckt). So if you
    have a 15A breaker, you're okay with 14AWG on one side (a little odd, but
    okay).
    If you want to use a larger, 20A breaker because of some heavy duty tools or
    whatever, you'll need to pull a new 12 AWG white wire.
    daestrom
  5. SQLit
    SQLit Guest
    Did you put this wiring in conduit?
  6. E. Hill
    E. Hill Guest
    It is.
    Eric
  7. E. Hill
    E. Hill Guest
    That's what I decided to do. Thanks.
    Eric
  8. E. Hill
    E. Hill Guest
    Ok. Thanks.
    Eric
  9. E. Hill
    E. Hill Guest
    Yes. 4' run of metal flex conduit.
    Eric
  10. Bob Peterson
    Bob Peterson Guest
    r u allowed to run 4' of flex?
