Think you will need to provide a bit more info here.
Like a link to the details of the module for starters.( appears to be some type of timer)
Then what you have tried in the form of how you made your connections, what power supply etc.
As it stands , power( no idea what....from the relay marked voltage maybe 12v dc) goes in on the right side 2 terminals, Vcc positive Gnd negative.
Output is either of the switching relay terminals common(centre left) and one of the either normally open or normally closed contacts depending on what you need the relay to do.
Jumpers appear to make changes to the operation.
