MichaelsVintage
- Apr 8, 2017
- 9
- Joined
- Apr 8, 2017
- Messages
- 9
Hello everyone!
Please don't be scared by all the text!
My name is Mike Clifford, and I work on vintage race cars for a living. I take care of European sports, formula, and sports racing cars from the 1950s and '60s, and take them to tracks all over the Eastern U.S. It's different and quite a bit of fun, but I'm sharing that to show why I have so little electrical know-how : )
My daily driver is a 1987 BMW 325i. I just bought an awesome pair of Recaro seats for it. Both seats have heat power reclining, and a little air compressor which fills lumbar bladders.
I'll be wiring the heating elements in using the factory wiring harness and plugs, so no issues there. I need help with the wiring for the recline and the compressors, however.
Each seat has a red wire and a brown wire which control both functions. The buttons to control recline/air compressor are on the seat, and they're lighted. This was my plan for wiring these into the car:
The car has an auxiliary fuse box from the factory with a hot lead and a switched lead. Since the buttons have lights, I need to attach them to switched power to keep from draining the battery. My thought was to wire in a 4-pin relay. The power source pin would run to the fused hot lead, the switch pin would run to the switched lead, the load pin would run to the red wire on the seats, and the ground pin would run to the brown wire on the seats.
Since there are two seats, it was my thought to tap into the load wire and ground wire running to the first seat and tee off to the second seat. The relay and fuse are rated for enough current to handle simultaneous load from both seats.
Please let me know what's correct and what should be done differently. I can provide photos of the seat, seat wiring, auxiliary fuse box, and whatever else may help.
I want to make sure this is done correctly and this seems like a great place to find some help!
Thank you in advance!
