wiring color schematic (pinout)
Discussion in 'Datasheets, Manuals and Component Identification' started by HarleyDoug, Sep 19, 2011.
  1. HarleyDoug
    HarleyDoug
    Sep 19, 2011
    Can anyone tell me where I might find the colors for the pinout on a Gigawear headset. I tried the company website but no luck. Any help would be appreciated. I am trying to wire a 7 pin din (using 5 pins) on the end of the cable after cutting off the USB end.
  2. shrtrnd
    shrtrnd
    3,827
    520
    Jan 15, 2010
    I can't help with the Gigawear.
    The USB connection should be standard.
    Look-up the USB pin configuration, and you should be able to find out which wires
    from the Gigawear went to which function on the USB.
    (You've got both wired ends of the cable you cut, so you can follow the wires to the
    pins, right?).
  3. HarleyDoug
    HarleyDoug
    Sep 19, 2011
    Thanks shrtrnd, I really didn't think of going the reverse route.
  4. shrtrnd
    shrtrnd
    3,827
    520
    Jan 15, 2010
    Yeah, I think the Chinese are best at reverse engineering.
    (But us Americans still try to give them a run for their money).
